problems with control design labview 2010
I have install the component control design & simulation for labview 2010 (64bit), then activated with the code send by email, then i have restart my computer. But i can't have disponible this component.
Message 1 of 9
(3,982 Views)
Try to search in installed programs to see if it is installed properly.
Hope this is anwer.
Jamal
Message 2 of 9
(3,960 Views)
Which version of LabVIEW are you using? Presumably if you installed the control design toolkit 2010 (64-bit), you are using LabVIEW 2010 (64-bit). If that's not the case then you need to install the correct version for the version of LabVIEW you have installed.
(blog)
Message 3 of 9
(3,946 Views)
I have labview 2010 (64bi) installed
Message 4 of 9
(3,921 Views)
thank you Jamal. All is ok. I have installed labview 2010 (64bi) and the component which i activate as no version, so i don't know it is compatible.
Message 5 of 9
(3,917 Views)
Is LV and the module marked as "Active" in the NI License Manager?
If you start LV, does it work as expected except the fact that the control design palettes are missing?
Norbert
Norbert
Expert: Geometry
Message 6 of 9
(3,906 Views)
yes. LV and the module is marked as active.
When i lunch LV all is working but the window of the module as nothing to choose.
Message 7 of 9
(3,891 Views)
lauramts@isec.pt wrote:
[...] but the window of the module as nothing to choose.
Can you attach a screenshot of the dialog you refer to?
Norbert
Norbert
Expert: Geometry
Message 8 of 9
(3,881 Views)
Thnak you. I have resolved the problem. I have installed  the 64bit version of labview 2010. I have changed to 32bit version and now it's ok.
Message 9 of 9
(3,796 Views)
