problems with NI TPC-2206 and Labview 2016
I created a test project in Labview 2016 and I'm trying to load a hmi national instrument NI TPC-2206 and tried to find a tutorial or something that tells me how to download the project to respective screen but can not find and make the executable labview generates me but only for Windows 7 SP1 or later and does not leave me to generate wimdows embedded and that is the complication that at the moment
and seen the following tutorial https://www.ni.com/docs/en-US/bundle/371940g/resource/371940g.pdf
  but is not the same in Labview 2016 the .EXE is not support in the NI TPC-2206 and executable is only for windows 7 sp1 or later but not windows embedden
(3,539 Views)
Hi ntranx,
As I understand, I understand that you are compiling an exe using LabVIEW 2016 and trying to run it in your TPC. What Operating System do your TPC has? is it not Windows 7? is it Windows XP?
As you can see, LabVIEW 2016 is only supported by Windows 7 SP1 or later:
LabVIEW 2016 Readme for Windows
https://www.ni.com/pdf/manuals/374715f.html
If it has Windows 7, you will only need to install this in your TPC and it should work:
LabVIEW Run-Time Engine 2016 - (32-bit) - Windows
https://www.ni.com/en/support/downloads/software-products/download.labview.html#306337
If your TPC has Windows XP or previous, I recommend you to try to compile the exe in a previous LabVIEW version and make sure you install the appropiate LabVIEW Run-Time Engine version in your TPC to be able to run it.
Hope this helps, regards,
Daniel C.
(3,456 Views)
I have a NI TPC 2215 with WES7 and the same error.
LRTE 2016 cannot run on it.
I have the Image 1.0.1f0 without SP1...
Is there any update ??
(3,328 Views)
