problems with 3D graph application redistribution
Hello wireworkers,
i wonder if someone encountered problems with distribution of application that uses 3D graph objects. I've created application that uses NI 3D graph component and created installer with "Enable 3D graph support" check box enabled. However after installing this application on the windows machine without Labview two problems appeared: 1) "Error loading control. A newer version needed. The default settings for the control will be used." and after it 2) "You have 30 days to evaluate the Measurement Studio ActivX control..." and something like that. I don't get it. Why some newer version is required? and what with that evaluation period?
Have any hints???
Thank you in advance and Merry Christmas to everyone.
Alex
www.xinstruments.com - Custom Software for Industrial Automation
www.hdrconverter.com - Picture processing made easy
(3,351 Views)
Hi Alex,
I tried the process you described on my machine using LabVIEW 7.1 and could not reproduce the behavior.  If you can clarify the version you were using that will be helpful. I will have to clean a test machine and try it again without LabVIEW installed, and get back with you if the problem appears.  In the meanwhile, I found the following KB which, while not referring to the exact same problem you are describing, does address the evaluation message issue.  You can try to follow the steps at the end of the KB, and let me know if that worked.
http://digital.ni.com/public.nsf/websearch/1E1FB3C19E8E0A9986256F8D0077D0E6?OpenDocument
Aluma G.
(3,320 Views)
Thank you for response. In meanwhile i've found an answer on infolabview.org. So this error occured because of the conflict of LV 7 and LV7.1. I have both installed on my machine. I've been building application in 7 but LV 7.1 have replaced the required components with never versions. And when i was running it on target machine with the help of LV 7 runtime engine i recieved an error. The fixture for me is create an executable in 7.1. It's not very convinient but it works.
Happy new year to everyone!!!
(3,312 Views)
Hi Alex,
sorry you have an inconvenience to get around the problem - is it that you don't want to install the 7.1 run-time engine on the other machines? I am not sure why it is inconvenient for you, but feel free to repost if there's something else we can do to help 🙂
Happy Holidays!
Aluma
(3,299 Views)
