problems reading from 2 text file
Hello anybody...
I´m trying to read 2 text files using de "Read from Text File" function, but something is not working...
The first file ("list.txt") contain a list of strings, where which one means a valid file (ex: "c:\file1.txt"  without " ")
The first function reads the entire file ("list.txt") and the text read from the file (strings) are converted to a path (to be used by second "Read from Text File" function block)
Content of "list.txt":
c:\file1.txt
c:\file2.txt
c:\file3.txt
<EOF>
Each string is converted to a VALID absolute path (example: "c:\file1.txt" )and connected to "file" terminal  of second function. The second function should open "c:\file1.txt", but an error occurs:
"Error 1 occurred at Read from Text file in MYTEST.vi"
"LabView: an input parameter is invalid"
Of course, file1.txt, file2.txt.... are valid .txt files and de path, if entered as a constant, there is no problem.
Some suggestion?
I´ve tried EVERYthing, conversions, bundle, unbundle, build path functions...but didn´t work...
Thanks!
Julio Ribeiro
(3,472 Views)
Your appended path will be:
c:\c:\file.txt
You have the full path in the file you only have to convert that to a path. No path building needed!
Ton
My LabVIEW Ideas
(3,465 Views)
The first read function is set to read lines.  when you do this an array will be the output of the first read function.  Either parse a normal read function string for the file you want or search and index the string array when set to read lines.
I attached an example that will open all files in the file using a for loop.  I do not reccomend you implement this, it was meant for illustration between the different read function settings
Chris Co.
(3,460 Views)
Your filename ends in a nonprintable character (\n, or newline or possibly \r\n)! Set your string to display \-codes and you see what I mean.
One way or the other, you need to clean it up. One simple way is shown in the attached. Modify as needed.
SInce your line contains the entire path, basepath is redundant and must remain empty if you use "build path". Instead, just use the "string-to-path" primitive. 🙂
(3,460 Views)
Sorry...the VI "open_file" was not the correct example... In fact the path was only c:\file1.txt, where c:\ is not appended by Build Path function...
In resume: The result path  was only c:\file1.txt.
Thank you!
Julio Ribeiro
(3,449 Views)
Thanks, dude!
You´re right! at the end of line I have /r/n...Smiley Happy I removed and now is working.
Thanks everybody
Julio
Julio Ribeiro
(3,448 Views)
