problems reading cmos levels?
I'm using a PCI-6221 card on a digital input.  I hooked up a CMOS line to it and the following happens:
1) If I measure the voltage with a voltmeter, it says 3.3V
2) As soon as I connect the wire to the daq card port 0 line 0, it goes from 3.3V to 1.6V
3) When I run my program, it always says FALSE on the DIO line
4) If I connect a jumper between port 0 line 0 to +5V, it says TRUE
Is there any way I can get the cmos logic to work here without adding too much componentry (or using a different port)?  I'm guessing the weak pull down is dividing my voltage in half and it's not working.  Can I disable the internal pull down somehow?  Interestingly, I hooked up a quadrature counter to CTR0 on lines PFI8 and PFI10 and it seems to work fine without problems with the same logic!
I also have a PCI-6202 that I haven't hooked up yet.  Would this be any different?
Thanks for any help.
(3,201 Views)
Also I'm using a SCB-6868 if that makes any difference.
(3,200 Views)
I tried it with my Labjack and it works fine at 3.3V.  Any ideas what I can do to get Labview and my pci 6221 reading these 3.3V levels without dropping them 1.6V?
(3,181 Views)
These three posts have been combined into a new thread, so let's continue over there for simplicity.
(3,178 Views)
