problems installing a NI pci 6023e
I am trying to install a pci-6023e-board on a windows NT PC
to use together with Labview 6. The board is correctly
detected by the measurement&automation-explorer.
But when I try to start the Test-Panel I get a message:
In German: Das Gerät antwortet an der gewählten Basisadresse
nicht!
Translation (I am not shure if its correct):
Device does not respond at the chosen base address.
Are there any ideas, to solve this ?
many thanks
Peter
[See first answer for additional information]
(3,368 Views)
[Attachment(s) for question]
(3,368 Views)
Peter;
The first thing we could try is to uninstall both Labview and NI-DAQ completelly. After that go to the windows registry editor (Start->Run->regedit or regedt32) and delete, if there are, both Labview and NI-DAQ folders. Remove your DAQ board from the machine. Reinstall only NI-DAQ (version 6.9.1, if possible. You can download from our web site). Shutdown your machine and put your board back. Run test panel. If same prob shows, try to use a different slot on the same machine. If even that doesn't work, try to repete the same steps on a different machine (with Windows 98, if possible) to test the hatdware. If same problem shows, the board is bad.
You also have the option on going to http://www.ni.com/support/daq/winnt/pnp/pnt.htm to check some troubleshooting methods
we recomend.
Hope this helps.
Filipe Altoe
(3,368 Views)
