problems finding serial port
Having used LabView for some years in my last job, I am trying to get it used in my new one.
I have downloaded the evaluation software to prove to my boss it is worth having.
However, the simplest task is proving difficult.
I am communicating over serial with an instrument and cant find any ports.
I have used the visa search facility set to ?* (find all) it returns an error -1073807202 immediately.
Is the evaluation software capable of using VISA?
If so why can I not use any visa items without this error occuring?
Cheers
Dan
(2,825 Views)
VISA is a seperate installation to LabVIEW (Like DAQ drivers). Make sure you have VISA installed on the computer you are working on.
Good luck
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,825 Views)
Dan,
Shane's correct. Check out this KB:
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/6055ccb1c032d1dd86256c32004ec84d?OpenDocument
It has links for VISA. If you already have VISA installed, it's probably an older version, or was installed before LabVIEW, or is corrupt.
Scott B.
Applications Engineering
(2,825 Views)
Cheers Guys
I installed the Visa301runtime.exe file form NI web site and it works perfectly.
Dan
(2,825 Views)
