problems determining the x values from a double array for gaussian analysis
I am having troubles with my labview analysis. I am currently very new with this program and have little experience with the hardware that is being used. I am studying the NMR of fat to determing the solid-fat content and getting the readings on the computer. I have been able to create a waveform of this data using a 2-D array that has 2 plots. One is of each measurement that occurs each 2 seconds and another with an average of each 10 samples taken.
Now I would like to analyze the average plot using a gaussian fitting, and i would like to be able to make the center point a constant at 0. I am having trouble because I am unable to determine the x values for this analysis, the current x values being used right now are 1-x (which are just numbering each value obtained) If anyone has any input that would be great.
(2,600 Views)
Are you using the Gaussian Peak Fit.vi?  If so, you will need to get the waveform components with VI "Get Waveform Components" and retrieve the X and Y components from the waveform.  You will need to set the corresponding tolerance and method for the Peak Fit.  Furthermore, what do you mean by setting the "center point a constant at 0"?
I hope this helps
Nadim
Applications Engineering
(2,558 Views)
