problems creating a BMP file
    I am getting screen shot data from various instruments with the VISA read command, which outputs a string of data.  How do I convert this to a 2d array so that I create a BMP file?
Kaspar
Kaspar
Message 1 of 20
(5,765 Views)
Well, that depends on the format of the 2D data, and what the 2D data represents. This should be documented in the instrument's manual, which we don't have.
Message 2 of 20
(5,760 Views)
   I am getting BMP data from 2 differenet manufacturers. I will contact them to get the format. So once I get the format  how would I convert the output of the VISA read (which is string data) to the input that the Write BMP File vi needs which is image data?
Kaspar
Kaspar
Message 3 of 20
(5,755 Views)
Hi Kaspar,
i think your "string" data is a binary byte stream. If you know the format you can convert your data to an array of U8 and build your picture of it.
Hope it helps.
Mike
Message 4 of 20
(5,750 Views)
  Yes your are correct this is a binary data string from the instrument. I will try what you suggested. thank you!
Kaspar
Kaspar
Message 5 of 20
(5,741 Views)
And have you tried simply saving the data directly to disk?
Message 6 of 20
(5,735 Views)
   Yes I have tried writing the data directly to a file and have looked at it with binary file viewers. The file created does not have the BMP header info, it appears to just have the bitmap data. So it looks like I have to figure out how to convert  from the output of the VISA read, which is the binary data to image data, which is what the Write BMP file needs for a input.
Kaspar
Kaspar
Message 7 of 20
(5,730 Views)
Something like the vi attached is probably what you need.
You will need to modify it according to the specifics of your data.
Jon D
Certified LabVIEW Developer.
Message 8 of 20
(5,720 Views)
  I am using Labview 8.2, the vi you attached is in 8.5. Could you PLEASE (I have used the magic word) save the vi in 8.2 and post it?
Kaspar
Kaspar
Message 9 of 20
(5,715 Views)
I think an easier solution is to use the Flatten Pixmap function to generate that cluster. You just need to know what bit-depth you're dealing with so you wire to the appropriate input.
Message 10 of 20
(5,712 Views)
