problem with write a table to excel
I want to open an existing Excel-file from Labview with ActiveX.
I have used the Example "write table XL.vi"
I changed the code that I can open the existing file but I am unable to
select a different sheet in Excel.There is always the first sheet active
and I cannot change this.
Can anybody help me?
robert
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,894 Views)
wrote in message
news:8q4e0a$hsa$1@nnrp1.deja.com...
The workbook object has a "Sheets" property that returns a collection of all
the sheets in the active workbook. Use the "Item" method on this collection
to select the sheet you want- if necessary by cycling through all the
elements (use the "Count" property to find how many objects there are) and
using the "Name" property to get the name of the worksheet for comparison
with the one
you're looking for. Remember that everything is case sensitive.
(2,894 Views)
