problem with web publishing tool ..
Hi All,
I am trying to use web publishing tool  .
the page appears as in attachments ...
what is the problem ?
regards 🙂
(3,465 Views)
The 0.00% percentage loading error can be caused by the following:
  • Port 80 is being blocked by the Firewall on the PC for TCP/IP traffic. Try using a different port, such as 5000.
  • The LabVIEW Run-Time Engine on the computer does not match the LabVIEW version of the VIs running on the target
  • Windows security settings could stop the Remote Front Panel from loading. Try running your web browser as an Administrator (right-click on the browser icon and select Run as Administrator).
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,455 Views)
thanks james ,,
i have tried to change port number and run browser as administrator bt the problem stilll exist 🙂
also the labview run-time engine matched 😞
(3,448 Views)
Have you tried turning off your firewall?
Cheers
(3,414 Views)
