problem with 'unbundle' function
hello,
in another vi, i collect data (2 1-D array) that i bundle, i am also plotting this real time with XY graph - no problem about that.
Now i'd like to plot (off-line) the data that i've recorded but i have problems to unbundle it (i am using the 'unbundled' function).
does anybody has an idea how to do that?
thanks,
guillaume
(3,898 Views)
Sounds like hierachial data typing.
Are you bundleing the 1D arrays and then building an array of bundles? You can't unbundle that directly - you'd need to separate the array of bundles and repiece them into a single bundle of 2 arrays.
One alternative way is to use shift registers (see ex.)
2006 Ultimate LabVIEW G-eek.
(3,898 Views)
hello,
i cant read the LV6.1 binary executable you sent me because of an older version of labview. would you send it to me in the former version?
thank u so much,
guillaume
(3,898 Views)
LV 5.0 version
(3,898 Views)
thanks,
now i understand best how it works.
Unfortunately the data i collected cant be collected again (clinical data). Actually i am able to plot the entire data set (recorded in the bundled format) after the acquisition. but what i finally want to do is to display ma data point by point.
Do u think is it possible? if yes do u have an idea how?
thank u again,
gt
(3,898 Views)
In order to display your data point-by-point, you will want to modify your graph/chart properties on the front panel of your VI. First, [right-click] on the graph display within the front panel, select [Properties], and select the [Plots] tab. Now, you will want to select the �pt-by-pt� icon and select a suitable data point display format (see attached image, I chose hollow points to display data).
Now, your plot will be represented pt-by-pt, and you will be able to easily differentiate between discrete data points.
I hope this helps! Please let me know if you need further assistance.
Best Regards,
Joe Des Rosier
(3,898 Views)
Thank you,
guillaume
(3,898 Views)
