07-11-2006 10:12 AM
hi
ya put format string as denis said earlier but it was giving me error.so tried different ways to get output but couldnt
i tried all possible formats but it didnt worked.it was saying sacn failed.
thank yuo
naveen
07-11-2006 10:20 AM
07-11-2006 10:29 AM
07-11-2006 10:41 AM
07-11-2006 10:44 AM
hi
thank you lynn and dennis for your help. hanks a lot for helping me in solving my problem.
naveen
07-11-2006 03:33 PM
hii
previously i was using serial port read and other serial port functions to establish communication with instrument and i managed to get output.But now i want to read and write from the instument and i want to use property node to read n write the parameters.i have witten some part of code and i am attching that code.plzz suggest me wt to do next to get complete interface with device so that i can add various functions later on
thanking you
naveen
07-12-2006 07:30 AM
07-12-2006 09:01 AM
thanks lynn
how can i inter face with the device.this prog is running continuously .so how can read n write into the devise
thank you
naveen
07-12-2006 09:27 AM
07-12-2006 09:56 AM
hii lynn
the program is going to idle state and running continuously with out giving any output.even though i ran prob putting in read mode,its not giving any output instead its going to idle state and running continuously
My VI is a temperature controller.Here what i basically need to do is Write set temperature to the device and then read present temperature as well as set temperature.i may need to run continuously and obtain the display of output and need to plot the output temperature vs time.i use Rs 232 cable for interfacing.plzz suggest me how can i do this.i am new to labview.,so plzz give me detailed information.
thank you
naveen
