problem with the RunTimeVersion
hi!
I have changed some programms in RunTime Version with the LabView
Application Builder , but I met a problem with the programm
for the balance, that it can run well under LabView but it shows always
0 under RunTime Version(wrong!), now I don't know what to do with it,
could someone help me?
Thanks!
Le
(3,015 Views)
Le,
Are you saying that the version displayed in the splash screen is "0"? If so, then that is very strange, and about the only thing I could think that could cause that problem would be a modification to a registry entry. Go to Start >> Run on your computer and type "regedit" (without the quotes). Navigate to HKEY_LOCAL_MACHINE >> Software >> National Instruments >> LabVIEW Run-Time and make sure that there isn't a folder there named "0" or that your "Current Version" isn't given as "0". If it is, then you should change it to the appropriate version number.
If this wasn't your problem, or if the suggestion I gave doesn't fix it, please let me know, and if possible, attach a screen capture to your message so that I will see the problem you are describing.
I hope t
his suggestion helps. Thanks for your patience, and have a pleasant day.
Sincerely,
Darren Nattinger
(3,015 Views)
What shows 0? You'll need to provide more information.
What do you mean by balance?
Jeff
"yu" wrote in message
news:3B03ACBA.A911ECAE@biovt.rwth-aachen.de...
> hi!
> Thanks!
> Le
(3,015 Views)
