problem with save in excel
hi
i am fetching problem when i am storing two value in excel
when i put write to measurement filt.vi in for loop that time unnecessary data also came in it.
and while i am putting measurement filt.vi outside the for loop that time only last data save
i want to save two data in two collumn
so pleaze help
Message 1 of 13
(4,130 Views)
Message 2 of 13
(4,121 Views)
hi
i am still facing same problem which i have posted
Message 3 of 13
(4,103 Views)
Try the attached example. Never build array for a long time it will lead to Out of memory error.
Message 4 of 13
(4,098 Views)
hi
i want to store my data in excel in form of two column not to take from other file suppose after giving input 2E+9 to stop at 3E+9 i will get different value according to that in form of 0.0 to 0.6 like that value i want to store in excel i dont want to read any file.
thanks
Message 5 of 13
(4,094 Views)
Hello hussey,
In your post code do some basic two modification.
1. Keep your file Dialog VI outside the loop.
2. Make append to file boolean to True.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 6 of 13
(4,080 Views)
@husssey wrote:
hi
thanks
Did you see the code and run it?. Where is it reading from a file?
Message 7 of 13
(4,076 Views)
hi
if i am doing this then i am grtting only one value in output in excel file.
thanks
Message 8 of 13
(4,073 Views)
hi     p anand
in your modification you are trying to read a file while i want to only store the data from two different points only
thanks
Message 9 of 13
(4,071 Views)
No before running just select the .xls file path and run I didn't have time to test the code thats why I just posted. Do this and tell what you got
Message 10 of 13
(4,068 Views)
