problem with object tracking vi
hi every body
i'm trying to use the camera to track any object selected on the screen in real time .
i didit with pattern matching and i wanna make it with object tracking vi, but i'm facing a problem with ROI and object detection
any help please !?
Message 1 of 8
(4,516 Views)
What is the problem you are having? You need to provide details if we are going to be able to help.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,482 Views)
what is the problem u r facing with those vi's ,,...share the screen shot of the issue or exp it in detail
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
Message 3 of 8
(4,472 Views)
when run the program an error apperes says no object to detect i creat a ROI to determine the object but another error says invalid ROI
here are the screen shots
Message 4 of 8
(4,447 Views)
Well, if the image on the screen is the one you are trying to process, I would say right off hand that the first problem is that the contrast is way, way to low.
Mike..
LabVIEW Champion
Message 5 of 8
(4,437 Views)
no the program stops before the camera works so every time  i trying to run i get the error and camera stop working efore the streaming begin
Message 6 of 8
(4,406 Views)
good... can u mention what type of camera you are using (camera model) and also tell me whether u have verified the working of the camera in NI MAX...
Message 7 of 8
(4,370 Views)
i'm using HP -HD usb cam.
what do you mean of camera verification ?
the camera works great with pattern matching , so i don't think there is a need to verify , the main problem with the internal structure of program as  mentioned in the post .
Message 8 of 8
(4,347 Views)
