problem with normalized frequency on fft
Greetings
I have a problem when working with vi fft Spectral measurements, when acquiring an analog signal , the frequency of this switch to a digital frequency affected by the sampling rate, and hence the frequency axis ( of a waveform graph) gives incorrect, how can  I multiply the digital frequency by the sampling frequency to obtain the original analog frequency?
how can I save as a text file in 2 columns (frequency and magnitude in db)? I tried to write with 'WRITE measurement FILE' but  shows a header file and the columns are time and value, there is another way to store this data?
thanks
(3,730 Views)
It's all just data. You can easily generate a frequency column based of f0 and df and write the two colums to a plain spreadsheet file.
Can you attach a simplified version of your VI so we can better see what you are doing?
(e.g. Do you use plain arrays, waveform or dynamic data? Which fft tools are you using?).
(3,710 Views)
greetings and thanks for answering
attached the vi I'm using, the questions are 2
1. How can I multiply the frequency of the signal by the sample rate to get the right analog frequency for  example (if the sample rate is 1000 for a frequency of 60 Hz , i got  0.06 Hz observed  on the waveform graph)
2. How can I get a flat file without a statement at the top with 2 columns frequency and magnitude db
thanks
Im using labview 7.1
(3,697 Views)
The Convert To Dynamic Data is incorrect. You selected to convert from 1D Array of Scalars instead of Single Waveform. Y A big clue that it's incorrect is the coercion dot on the input. You stripped all timing information so that is why the x axis is wrong.
If you want somthing simple, use the Write to Spreadsheet File.
(3,693 Views)
