problem with ni usb 6008
Hi. I am currently using a NI USB 6008 device with 4 differential analog inputs. What i want to do is get the four inputs and average them and graph the result. The four inputs are thermistor outputs from a voltage divider circuit. I thought i had it working but it would only graph one point for me, and when i stopped the program a dilog box would appear with the message "Ressetting VI: USB-92xx Bulk Reader". Can anyone help with this please. It would be much appreciated. Thanks............
(3,065 Views)
Hi!
See the attached file, hope so it will work for you.
If it will not work, send me your vi, i will modified it.
Kaustubh
VC (PUNE)
INDIA
(3,058 Views)
Hi Paul,
Thanks for your post.
Please find attached an example VI that reads in differential measurements on 4 channels. The data is then plotted as raw data, and as an average.
The un-bundling and bundling of clusters in this VI eliminates an anomalous reading of 0 from an extra, non-existant, channel. I have noted this behaviour to R&D in the U.S.
I hope this helps. Let me know how you get on.
National Instruments | Northern California
(3,030 Views)
yes that was great thanks very much. Problem Sorted...........
(3,017 Views)
