problem with kernel.cpp
I am running a compiled 6.1 program and getting this error:
Failure : "kernel.cpp", line 776
After the message is cleared, LabVIEW exits.
(3,163 Views)
Hi mark6i,
I would be surprised if this problem hasn't been fixed in a newer version of LabVIEW.  Any possibility that you could upgrade?
If you can't upgrade LabVIEW, I've also seen instances where upgrading device drivers that are used in your program (such as NI-Serial, NI-4882, NI-VISA, etc.) can make this error go away.  If you are using any of these packages, I recommend you visit our Drivers and Updates page and see if any newer versions are available for download.
National Instruments - Drivers and Updates
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
(3,135 Views)
I just ran into the same problem. And in this case upgrading to a newer version of labview is not an option.
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
(3,050 Views)
