I am using a PCI-7831R RIO device. All my VIs used to run fine until my PC crashed. Now I have installed the PCI card in a new PC and copied all the VIs including the project (.lep) files and embedded FPGA code (they are in the same folder). But now I am facing some problems. I have built the project freshly by compiling it on the FPGA target and downloaded the VI to the flash memory of the board. The VI targeted to the FPGA device is working fine and is actually able to read the input ports. But when I am running the host VI targeted to windows, all the returned values are Zeros.
Is there any FPGA configuration problem ?? I am using LabVIEW 7.1 and NI-RIO 1.1
I am attaching the VIs herewith.... Display.vi - the host VI targeted to the PC windows output.vi - the FPGA VI and output.lep is the corresponding project file.
Attaching two screen shots too...
The first one (Targeted to PCI 7831R.jpg) shows the smooth running of the output.vi file targeted to the FPGA board and returning the values, while the second one (Targeted to windows.jpg) shows the host VI (Display.vi) that calls the FPGA code (in open and run mode) and returns zeros always.
