problem with duplicate axis function of the graphs?
it is impossible for me to plot for instance two different curves on a same XY graph when they have different y axis ranges, the duplicate axis function of the graph is not working; i am not able to fix a scale to a specific curve whereas this was working well with the previous versions
do anybody faced the same problem or have a solution?
(2,560 Views)
I don't know if you can use XY graph for it.. but Waveform chart should do the same thing...
Here's what I did...
1.  place a waveform chart on the front panel
2.  duplicat scale and swap it to the other side
3.  bundle the two plots and input it to the waveform chart
4.  drop the box in the upper right corner of the waveform chart (on the front panel), so it shows plot 0 and plot 1
5.  open properties of the waveform chart
6.  got to the Plots tab
7.  click on the dropdown box at the top ("Plot 0") and select Plot 1, click on the Y-scale drop down box and select the other scale
8.  click OK, then reopen properties
9.  go to the Plots tab again, it probably shows Plot 0 is using the 2nd Scale (at least it does that to me everytime), click on the Y-scale box and reassign Plot 0 to the 1st scale
10. click ok, then reopen properties to change the other settings
this works for me everytime now, hopefully it'll work for you ^_^
(2,555 Views)
