11-21-2008 04:08 AM
I try to build a excutable file with labview application builder 6.0, but there was a problem. I am using Labview 7.1 and I don't know if there is a software compatible issue or not. When I opened the tool menue in Labview pane and selected build application or shared library (DLL), the build application window pop up but together with a window showing error list. The first error in hte list is Dist Send Result File To RT.vi, and the second is Build Appliation.vi. When I double click the block diagram errors (Invoke Node: contains unwired or bad terminal), another authentication window popped up and ask to enter password to access block diagram. But I entred my labview s/n, but it didn't work.
Can some one help me to solve this problem?
many thanks
11-21-2008 09:17 AM
