problem with VISA read
Are you sure you are using the correct serial cable?  Are you using a null modem cable when it should be straight through, or vice versa?
Message 11 of 15
(977 Views)
That manual is essentially useless.  The little Basic code segment makes me wonder if the device uses hardware handshaking. I am not sure what the "...CS,DS,CD" part of line 10 does, but it appears to refer to handshaking lines.
Is there a programming manual for the instrument?
Lynn
Message 12 of 15
(966 Views)
yes...it use only rs232 cable.i have asked my friend who have done some experiment with the same instrument before.she said when she done the exp. she just connect the instrument to the pc with rs232.and choose the port and labview will display the data.
right now,im not sure whether there is somethg wrong with the pc im using or not.because i also tried some tutorial in youtube http://www.youtube.com/watch?v=RM8a66g2eGo but failed.
Message 13 of 15
(951 Views)
there is no other manual.ive tried google the manual but no info about it
Message 14 of 15
(949 Views)
I'd suggest you contact that friend and have her come and give you a hand with it.
Message 15 of 15
(942 Views)
