Hello ,
I am trying to use the example "TCP data server/client -Pocket PC" from the example database on Labview help. The same problem happen when the PC is the host and the PDA is the client or visversa. When I run the host vi. and enter the host IP in the target and press "connect" the host identify the client IP and puts a check mark on for good connection. However, then I recive two errors on the client and on the host. On the PC the error says :"TCP read in TCP data client-Pocket PC.vi Error code:66".On the PDA the error is :"WinsockRead error Error code:10060".
I will appreciate your help in resolving this problem
Eran
