problem with READ PNG FILE
i read a png file - a picture with transperent back ground - with READ PNG File and display it in my program using a Draw Flattened Pixmap function.
i get a very dark background- black coulour- in the picture created.
How can i resolve this problem???
Please give your suggestions
Many thanks in advance
RENN
Kudos always welcome for helpful posts 🙂
Message 1 of 17
(5,543 Views)
Message 2 of 17
(5,514 Views)
its better if u give suggestions coz...i dont mind asking a question till it's answered be someone
Message 3 of 17
(5,507 Views)
Hi ..
 As you said i tried to read a PNG picture with transparent background but i didnt experience any dark backgroung after reading just check by changing the value of transparency thrash in read PNG file.
Message 4 of 17
(5,502 Views)
"RENN" <x@no.email> wrote in message
news:1225955412767-804492@exchange.ni.com...
But we do mind.
Message 5 of 17
(5,485 Views)
Accepted by topic author RENN
RENN,
Probably you monitor is too dark and you should just increase brightness a little bit?
Seriously, when you post such question - its always goot to include an example. In this case: a) image and b) source code snippet - how do you use it?
Look here - I haven't any big problems:
The only small problem that semi-transparency is not supported. You should set threshold (which is 127 by default).
See attached example.
with best regards,
Andrey.
Message Edited by Andrey Dmitriev on 11-06-2008 12:19 PM
Message 6 of 17
(5,476 Views)
Hello!
I have the same problem. In your example I don't see the half-transparency of the picture, but I want see the same picture as drown in original.
Can anybody help?
Thank you, Eugen
Message 7 of 17
(5,437 Views)
In Andrey's example, they didnt show half-transparency, they showed full transparency.
What is the problem you are having? Their code works fine.
Cory K
Message 8 of 17
(5,433 Views)
Can't You see the difference between original and imported picture? The blure effect?
Message 9 of 17
(5,431 Views)
I'm programming a CAR PC software and need this functionality. Compare the original Icons and imported to the Front Panel and you will see what I mean.
Message Edited by Eugen Graf on 11-06-2008 06:02 PM
Message 10 of 17
(5,423 Views)
