problem with Digital bit out
I'm posting my whole code graphic in case it is needed for clarity.
I have a JK flip flop that is wired to an LED, this LED toggles with the state of the line no problem but when I connect it a a digital bit out(DAQ) I get nothing(when the state goes high). When I hook up the control just under the DBitIn I get an output.
Can't this be hooked up in this way?
Ron
(2,806 Views)
It is not possible to see what you are doing at the subVI level..
Could you send the vi and not the printsceen
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(2,806 Views)
Sure, this is from Labview 4.0
(2,806 Views)
