problem with DAQmx BASE
I'm able to create a task with using NI-Daqmx Base Task Configuration utility. I'm trying to create a DIO task for my application, when i set the output port as 0. The application works. But, when i change the output port as 1,2 and 3. It doens't work. Anyone know why is this happening?
Thanks.
(2,520 Views)
Duplicate thread
http://forums.ni.com/attachments/ni/70/8472/1/movement.vi</msg_body>
Please only post in one forum thread at a time
Rob L
NI Applications Engineer
UK & Ireland
It only takes a click to rate this message 😉
(2,494 Views)
