problem when I create a library automatically using a vi.
I create a library which contains a Shared Variable by the vi as the attachment shows, but the property of the autocreated Shared variable is not same with which I set in the vi, mainly in the propertys of Network.AccessType and Alarming.BadStatus.Enabled. But other propertys are same with which I set, What's wrong with this Vi?
LabVIEW 8.20程序设计从入门到精通已经出版,敬请关注!
欢迎访问LabVIEW学习乐园: http://labviewstudy.blog.edu.cn
(3,467 Views)
refresh
(3,449 Views)
refresh again
(3,437 Views)
New problem: the created libarary cannot be deployed with the error: MyLibrary\My Variable deployment failed (error: -1967362041).
After you dobleclick every shared varaible and click ok(without any change), then the libarary can be deployed successful!
It's very strange to me, can anyone explain this?
(3,431 Views)
unluckly, no one reply meSmiley Sad
(3,411 Views)
