problem to read a fifo (compactrio)
I have a problem to read a fifo. I acquire sound at 20Khz on a compactrio (NI 9263). I have configured a Fifo target to host of size 2047. So normally, with a sampling of 20 KHz, my fifo must be full after about 100ms. I have attached a picture of my fpga VI.
So, in my RT VI, I read the data every 50 ms to prevent to have a full fifo. I transform the 16 bits integers into double and then want to plot the data in a waveform chart. But nothing is plot and I don't understand why. I also attached a picture of the RT VI.
Second question: In my fpga VI, I also generate a uniform white noise whith the "white noise generator". I want to generate a white noise of 0.5 V amplitude. So because the range of the NI 9263 is +/- 10 V and is coded on 16 bit, the step is 20/(2^16)=0.3051mV. So I set the amplitude to 0.5/0.3051mV=1638 to have a 0.5V at the ouptut. But when I mesure the output on an oscilloscope of always have a uniform white noise signal of +/-10V. Why?
I Hope somebody can help me.
(2,748 Views)
Follow the guidelines for using the new fixed-point data type here:
Do you get any error messages / warnings in your RT application? Please monitor these when you have applied the guidelines above in your applications.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(2,708 Views)
Thanks you for your answer Jimmie A. !
I have read the guidelines and applied the conversion to fixed points. Now it seems to work. I can transfer the datas from the fpga VI to the RT VI using the DMA FIFO. The error was that I wanted to put in directly fixed points values in the FIFO but only 16 bits integers are possible.
 I just still have a strange behaviour with the amplitude of the uniform white noise generator. I also transform the value from fixed point to 16 bits integers before going to  the amplitude terminal.  When I set an amplitude of 1, I have well 1V at the output of the NI 9263. If I set 0.7V, it still works, but if I set 0.5V, nothing at the output. As if there was a threshold to switch on the uniform white noise generator.
I attached my corrected VIs
Thanks you
(2,695 Views)
