problem to connect remote panels
hi
I have some problem when I want to connect web pages that have remote panel.I used dialup networking (from ISP) to connect to Internet and for example when I go to this page
"http://www.ni.com/webappdemos/rc_demo.htm"
to viewing the remote panel it depends which dialup number I uesd .can anybody help me to understand the reason and how to solve it. thank you
(2,647 Views)
Hello Behzad,
I'm no expert but quite experienced with LabIEW features.First, is that running remote panels is possible only for version 6.1 and 7.0.For you to run remote panels successfully (which I did in our lab with five remote panels sharing a motorized microscope) you must see to it both the remote and the local panel have the same LabVIEW versions and each have correct Run Time Engines (which you can download from NI).You may run into network security problems for certain IP address that which network has firewall or required priveleged access (your system administrator can help).Or otherwise if everything seems ok always check of the remote site server is actually there or is down.
Berns B.
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
(2,647 Views)
Hello Dr.Berns
thanks for your response.I think your answer is correct and I run into network security problems , because I hvae correct Run Time(version 7.0) and the site is ok (you can access it from this link)
I can see the page without remote panels and I test some other site so the IP seems to be ok and I finally I think I should ask my network administrator about the setting , but I don't know what to ask.can you help me? (they aren't familier with labview)
Regards
(2,647 Views)
