problem programming Timed Loop period
I was trying to use the Time Loop in a FPGA target. I lost all day trying to figure out why the Time-Loop worked at a fixed period instead of the period I programmed. Finally I found out in this website that the time-loop works different in a FPGA target than in a normal VI. National Instruments should add a hint on the "Context Help" about this.
Isaac
(4,120 Views)
Isaac-
Which version of the FPGA module are you using? The context help for the timed loop in 8.0 and 8.2 reads "...If you use the Timed Loop in an FPGA VI, the loop executes one subdiagram at the same period as the FPGA clock." If you want a custom loop exeecution time, I recommend using the Loop Timer inside a while or for loop instead.
Xaq
(4,089 Views)
I am ussing Labview 8.2.
Thank you.
(4,078 Views)
Dear Issac,
When you code VI for the FPGA target you should always thing that you are very close of the hardware.
As mentioned in the context help and the help of LabVIEW,
If you use the Timed Loop in an FPGA VI, the loop executes one subdiagram at the same period as an FPGA clock.
The SCTL provides faster execution of the LV FPGA diagram, allowing each cycle of the loop to execute in one clock cycle. This enables up to update a signal line at the FPGA base clock frequency. The SCTL also optimizes the code generation so that the code on the FPGA is more efficient and uses less FPGA real estate. However, there are several restrictions on the code implemented inside of a SCTL
To have more details about the timed loop (SCTL) you can have a look at the following link :
help:Timed Loop (FPGA Module)
Using Single-Cycle Timed Loops to Optimize FPGA VIs (FPGA Module)
Nick_CH
(4,075 Views)
