problem opening VI
Hi
My VI can't be opened any more. The below msg is displayed whenever trying to open my VI with LV.  Any way to recover my VI? Pls help.
 Labview: memory or data structure corrupt.
An error occured loading VI
Labview load error code3: Could not load front panel
Message Edited by rdtttttttttttttt on 02-11-2009 11:47 PM
(3,312 Views)
You will need to explain the issue in greater detail. What version of LabVIEW are you using? When exactly did this error start occuring? Had anything changed in the system at that point in terms of installation of new software, application etc.? Are you opening an executable or opening a VI?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,299 Views)
Using LV 8.6. I did not change anything in my code(block diagram). I have been using 8.6 since the start of my application development. Nothing has been change in my system. I was able to open my VI just now(in the morning). Went for a break, came back, tried opening the VI but in vain. Any chance for the VI to reside in the archive backup of Labview. This is critical. I need to recover my app. I dun have a backup.
(3,295 Views)
Have you tried opening this VI on some other system in your office? If so, I would recommend that you contact the local branch of NI and speak to the support team over there. Maybe they can help you out?
Adnan Zafar
(3,293 Views)
