problem of installing biomedical startup kit 3
hi. I have installed labview 8.6, runtime engine and biomedical startup kit 3 on Windows 8.1. Why can I not find the biomedical kit on functions panel in labview8.3? I also installed labview 2012, but cannot find either. please help me with that.
(3,189 Views)
Did you install the toolkit after installing 2012?
(3,184 Views)
What exactly did you install and in what order? What is LabVIEW 8.3?
Also note that LabVIEW 8.6 and LabVIEW 2012 are not officially supported in windows 8.1 (details).
(3,182 Views)
I installed labview 8.6 and biomedical startup kit 3 first, but it did not work. so, I then installed labview 2012. it failed again.
(3,162 Views)
I installed labview 8.6, run-time engine and biomedical startup kit 3 first, but it did not work. so, I then installed labview 2012. it failed again. does the installation order matter?
(3,161 Views)
Of course it matters. Support cannot be added to non-existant software. Reinstall the toolkit.
(3,154 Views)
Thanks, Dannis. I tried to install startup kit 3 in the order: labview 8.6, run-time engine, and BM startup kit 3 on Win XP pc, but it stll doesn't work.
(3,142 Views)
