problem in feedback loop
Hi i have problem in the feed back loop inside while loop.i have attached the demo program .in that example u need to give two string such as string 1= 1,3,5,7 and string2=2,4,6,8 if u run the program and enter this value and click ok button  the output string will be 12345678 .it is fine.if u continue with out stoping and change the value seperated by coomma in two string .the value of 3 string does not change this is because of feed back loop it retains the value in last iteration.is there any way to eleminate the value
Message 1 of 13
(4,505 Views)
Hi parthipan,
I hope your well.
I have done some code for you. I used the search string for token vi.
Kind Regards,
Message Edited by Hillman on 09-22-2008 12:30 PM
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
Message 2 of 13
(4,489 Views)
Hi i cant open the vi that u have posted since u have developed in labview 8.6.i have labview 8.5 can u change to 8.5 version and send me back.Thank you
Message 3 of 13
(4,482 Views)
Sorry about that.
Let me know what you think.
Kind Regards
Kind Regards
James Hillman
Message 4 of 13
(4,480 Views)
Hi i have implemented my code which contain many feedback loop.i have this problem with my code since i cannot post my code i made demo version(which work similar).you are trying to say if we use shift register instead of feedback loop we can get rid of this problem .or any other idea.Thanks a lot ya
Message 5 of 13
(4,477 Views)
Thanks for the post.
Well, as always with labview/programming, there are so many ways to do things.
I personally, never seem to use feedback loops. But the way i coded it seem to work.
Kind Regards,
Kind Regards
James Hillman
Message 6 of 13
(4,475 Views)
Hi i did not satisfied ya.i need to know why the feed back loop is not re initialising.is there any way to re initialise or itt is a bug in labview.i need to know answer for this only ya
Message 7 of 13
(4,472 Views)
shift registors and feedback nodes are very similar.
In your code I think the issue is the node isnt 'reset' to an empty string between button presses, its just remembering the last full combined string.
I would suggest looking at the example finder for my help on feedback nodes.
Kind Regards,
Kind Regards
James Hillman
Message 8 of 13
(4,464 Views)
what is the example finder i dont get u make it cleasr is there any link to this
Message 9 of 13
(4,452 Views)
Sorry.
Go to Help>>Find Examples>>Search Tab>>feedback Node in keywords>>Feedback Node - Build Array.vi.
This shows how to correctly re-initialise a feedback node.
Kind Regards,
Kind Regards
James Hillman
Message 10 of 13
(4,450 Views)
