problem in creating dll
hello,
iam trying to do some sample examples in creating and calling dlls using vc++. but when i open the .c file through call library function node its directly going ot .net instead of vc++ how do i change it.
vijay
(2,854 Views)
Hey Vijay,
You question is not quite clear. Which examples are you working with? Are you trying to create a DLL in LabVIEW and then call it in VC++, or is it the other way around? With the call library function node you would be calling a DLL, so I don’t understand what you mean by saying that you were trying to load a .c file. Kindly refer to the help for the Call Library Function node to get more information on how exactly to use it.
Chetan K
Application Engineering
NI
(2,828 Views)
thanks for the reply chetan i cleared the porblem
with regards
vijay
(2,790 Views)
