problem in build application
I build application (exe ) for my main VI  but there is main problem if run my main VI in another PC without labview there is problem see figure for explain may problem
(3,085 Views)
if you did not create an installer:
In the builder you should find a tab  installer and select create installer
(3,068 Views)
Creation of an installer will only help you when the "hpe363xa, nidmm ,niswitch" drivers are also included.
Beside an installer you could also install the drivers manually in the PC containing only the LV run-time.
André
André (CLA, CLED)
(3,034 Views)
