problem at transfer function configuration
Hallo, everyone. I'm a new user.
I've got problem at configuring the equation of transfer function.
It couldnt be change
Smiley Sad
Please help me to solve this issue. It's so urgent. So, thank u so much for the repply.
Nb: I attach the printscreen of problem window
Message 1 of 9
(5,453 Views)
Dear RanWidya,
welcome to the fori.
Could you help me locate the Tranfer Function, please? Where did you find it?
Message 2 of 9
(5,417 Views)
what transfer function do you want to enter?
Try to change the model dimensions.
Simyfren
PS: did you load some model?
Message 3 of 9
(5,408 Views)
I noticed the same "Parameter Information" within opening configure window. Maybe your LabVIEW is frozen.
Try to close and open the VI again.
Simyfren
Message 4 of 9
(5,406 Views)
For completeness:
Owning Palette: Continuous Linear Systems Functions
Requires: Control Design and Simulation Module
htp://zone.ni.com/reference/en-XX/help/371894F-01/lvsim/sim_transferfunction/
Message 5 of 9
(5,371 Views)
Accepted by topic author RanWidya
Hi, all.
So sorry that I just reply this now.
Thanks anyway for the respond.
But I solved this. The problem is the software I installed had broken. So, I download the installer again.
Message 6 of 9
(5,227 Views)
i re-installed everything but still transfer function configuration does not accept any values
Message 7 of 9
(2,730 Views)
Hi Ema,
@EmaEma wrote:
i re-installed everything but...
Please explain what you mean by "everything"!
You are writing in a 10 year old thread so probably you talk about other software (version)...
Message 8 of 9
(2,704 Views)
 i tried to install Labview 2024 64 bits on windows 64 bits and also tried to remove and install Labview 2024 32 bita on windows 64 bits--- as i read in a forum that this solves the issue of not saving any  entered values for numurator and denomenator of transfer function (in the control design and simulation module) as you can see it is greyed out and not accepting inputs
Message 9 of 9
(2,686 Views)
