probed value into file
How can I get the probed values stored inside a file ?
Thank
(2,982 Views)
pdupre,
That is an interesting idea.  I'm not aware of a probe to file feature.  You should be able to create an array with a shift register.  You could write/append this value continuously to a file.  -SS
(2,972 Views)
Right, but this requires to change the code, and a probe should work without touching the code !
(2,965 Views)
You might be able to modify Darren's custom History Probes.
You could change them to write to file or forward the probe data to a queue that could be flushed to disk later...
Message Edited by Phillip Brooks on 09-26-2008 01:12 PM
(2,951 Views)
