probe window values on a restart
hello,
The probe(s) will hold there value when you stop and restart a simulation but it can be confusing if your code is working properly if the value are retained from the last simulation. Can the Probe values be reset somehow between each simulation??
thanks
(3,056 Views)
Verify your Retain Probe Values is enabled in your simulation vi
AB
Kudos are Accepted
(3,034 Views)
This has nothing to do with the question asked.
(3,030 Views)
No.
(3,029 Views)
