print report file path in footer
The VI in the picture worked fine when I selected standard report (except that I couldn't save to file).  I changed to HTML and it moved my footer page number to the top of the page and put the path to the printing temp file on the bottom of the page.  Why?  All I did was change to HTML and add the save at the end.
Jim
LV 2020
(3,521 Views)
html pages don't have footers -- at least not in the usual sense of the term.
How were you wanting to save the standard report to a file? You could always print it to a PDF file.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,503 Views)
Can you post your vi?
(3,480 Views)
Hey Mike,
It may not technically be a footer, but it appears at the bottom of the page, and the page number that should be the footer is at the top.  I originally used the exaprom pdf VIs to create the datasheet.  Late last year I had some problems that appeared to be related to those VIs (or the DLL).  I don't recall what the issue was, but I got it working.  Now the program is crashing on start up and I don't know why.  I am getting an access violation exception error.  I sent the dump files to NI, but in the mean time decided to try native NI VIs to accomplish the task.  Creating the report was working fine until I switched to HTML format so that I could save it.
Jim
LV 2020
(3,471 Views)
I've heard a few things about those VIs (mostly not good). What I was suggesting was a PDF print driver. I have used those for many years without issue.
Mike...
LabVIEW Champion
(3,459 Views)
That's a good idea, don't know why I didn't think to do that.  I have used them as well for when I wanted to send a document that couldn't be altered.  The exaprom VIs actually have some good document foratting features that are IMO better than the LV ones.  How do you give a print to pdf file a filename?
Jim
LV 2020
(3,452 Views)
It depends on the driver you use.
Some prompt you for a name, some can automatically build a name for you, some just show the PDF in a window and you save it manually.
Mike...
LabVIEW Champion
(3,444 Views)
