print function not working in executable
I have created an application to generate a QR code. I am converting the QR code into the Bitmap file type and then i am appending the generated image to the report. After the report generation I am printing down the report. The report is generated as a Standard Report type. Everything works fine during the development time means in the .vi file. But when I create and executable application the print function is not functioning at all. Please guide me with this as soon as possible. Thanks in advance.
(3,193 Views)
Please attach your VI then it will be easy to answer.
What is the error message you are getting. Attach some snapshot.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,184 Views)
I used to use this to print a report:
...but it doesn't work on my Windows 7 computers.  So, now I use this:
...and I'm happy again.  🙂  You may be, too, if you're using Windows 7.  I found this post helpful when I experienced this problem.
Jim
(3,170 Views)
