print front panel
I have been going through messages for a while but just can't seem to find exactly what I'm looking for. I need to print a waveform chart that has two plots that update at about 10Hz. Simple enough, right? Problem is that the report vi's have no way I can see to easily enlarge the image. I tried putting a larger chart in a sub vi that prints after executing but the chart only get part of the data when I run it. Then I tried the invoke get image method but can't find an indicator for the image data. Is there a way to print an enlarged waveform chart image? It would be even better if I can just print a front panel of a subvi with the same data on the waveform chart that appears on my top-level VI.
PaulG.
Retired
(3,466 Views)
What I have done in these situations is to have a graphs that is sized to printout the size that I want. I then update the graph from the program data, grab an image of the graph using the Get Image method, and save the image as a jpeg file. I can then either printhout this file or include it in a standard report.
OR you can use Draw Flattened Pixmap.vi to turn it into a form that will go into a picture indicator
OR you can create a VI with the graph on its front panel that is set to print itself when it finishes executing - or which you print programatically
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,454 Views)
even i have a similar problem
please check this link below.
https://forums.ni.com/t5/LabVIEW/Probelm-with-Printing-FP-image/m-p/2246684#M713349
i tried changing the size of the image i created, but in the standard report its not working well. in an html report, the image fits well and is centred.
why is it so?
i use PDFCreator as printer.
LV 2012
thanks
Renn
Kudos always welcome for helpful posts 🙂
(2,763 Views)
