prgramatticaly using source code control
Does anyone know of any way i can programmaticly control the built in source code control system (or systems intergrated with it). Are there any VI's that can be used? I want to be able to control access to configuration files, and output files, and be able to see who has modified these.
Any ideas?
(2,747 Views)
Mathew,
Send me an email. My address is jim at jimkring.com
-Jim
(2,747 Views)
> modified these.
> Any ideas?
I changed behaviour of scc by modifying the built in service provider.
It a normal vi. You can stop it with ctrl-. and save your own version.
If I remember right it uses a string queue to drive a state machine.
You might be able to take some cases. It is easiest if just modify the
strings that are put into the queue. Then again maybe there's no
suitable cases for you. But at least you get some kind of an example
Juha
(2,747 Views)
