pressure control
I am currently resurching a project on pressure control and I am looking for some advice on compatable hardware to run with Labview 11 I want to control the speed of a Hydraulic motro through either a 4\20 mA or 0\10volt variable flow controler using a dac
(2,712 Views)
I am currently using an NI PXI chassis for control of a pressure system, and parts mostly from this company to achieve high pressures (>2000PSI): http://www.miltonroy.com
(2,696 Views)
