preferred execution order in executable
I have an application where I need a custom execution order (all one thread). This works for me when I run a VI but if I create an executable this does not seem to carry over. Is there a way to keep this execution order when making an executable?
(3,054 Views)
You need to show your code.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,051 Views)
My guess is that you are using local and/or global variables to pass data between sections of your code instead of using wires. In this case there is no garantee that the code will execute in the same order in the development code and in the executable.
Ben64
(3,022 Views)
Use error in - error out approach to make sure execution in order.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,002 Views)
--Ranjeet
(3,002 Views)
