I've found and made a bunch of vis that allow for interactive high/low control of the 8 data bits on the parallel port. I want to control each pin with a pre-programmed pattern of bits. Any ideas?
A U8 is an unsigned 8 bit number. To create one place a number control down on the front panel. Right-click on it and select Representation>>U8. To create an array of U8s you place an array control down, and then drag the above numeric into the array shell. You now have an array of U8s, which you can expand and place things in it.
