power supply code in labview
I am sorry.
   this is a dc high voltage power supply. I want to write a labview code for this power supply in serial mode. I have divided the whole experiment into different steps.
   Now what I want to do is bring the power supply into remote mode, apply a set of voltages by defining the min. voltage and max. voltage and also define the step size of the applied voltage. For eg. I want to apply voltage from 1V to 5V with a step size of 0.5V. I also want each voltage to be applied to the load for atleast 10 sec(though the time can be varied). After it finishes applying the set of voltages the program should stop.
1. Initialize 2. Define Min. voltage, Max. voltage and the step size of the voltage applied 3. Apply voltage 4. The voltage should be applied for 10 sec. 5. Check if applied voltage is equal to Max. Voltage. If true then stop, if false return to step 3.
i hope the logic is correct. Now how do I write the code of this program, particularly for the step2,step4 and step5.
good day!
(3,298 Views)
Please use the REPLY button instead of making a new thread when answering a post:
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,294 Views)
stick in your original thread!
(3,281 Views)
