post uut callback
I'm have in place a custom callback library for use with a run-time test exec environment. I modified one of the VIs in callback.llb associated with report printing but now the test executive runtime returns the error that it cannot call post-uut callback.vi (which was not modified). Any help would be appreciated, and I would like to avoid rebuilding the test exec application if possible, as it would mean deploying the new application on several stations rather than just updating their callback.llb
(2,840 Views)
I don't have Test Executive, but I would certainly guess that if you modify core VIs, bad things may ensue. I would start by checking the VI it says can not be called and then see if any subVIs in that one call the VI which you modified. I don't know if this helps much, but hopefully it can get you started.
J.R. Allen
(2,840 Views)
