possible bug with enum control
There seems to be a problem using the "Strings []" attribute node for an
"Enumerated Type" ring control.
I can read from it fine, but if I try to write a string array to it,
nothing happens to the strings in the control. I don't have this
problem with a "Menu" ring control. Most peculiar. Writing to other
attribute nodes works fine, such as the "visible".
Enclosed is a very simple vi (LV5.1) that demonstrates this.
Chris
[See first answer for additional information]
(3,138 Views)
[Attachment(s) for question]
(3,138 Views)
> Chris
> test.vi Type: LabVIEW Instrument (application/x-unknown-content-type-LabVIEWInstrument)
> Encoding: base64
Chris,
This is definitely not a bug, because thi
s attribute is read only. Refer
to online help and click on the property node to check. Use menu or
another with permitted write attribute.
Sergey Krasnishov,
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
(3,138 Views)
