polymorphism of "number to decimal string"
I'm in the progress of rewriting an older application. Here I found an interesting behaviour:
The "Number to decimal string" function should be polymorphic (as described in the context help). In fact it takes any scalar integer number without type coercion. But when I wire an I32 array (which is no problem in general) this function shows a coercion dot?!? This coercion dot is not shown in LV7.1...
So I'm questioning:
What is coerced here? To which datatype is the data coerced? May there some problems arise from coercion?
(3,181 Views)
This had been raised by altenbach here.
(3,163 Views)
Thanks smercurio,
so this seems like a bug not solved by the 8.6.1 update...
(3,157 Views)
It is still not fixed in LabVIEW 2013 SP1.
Is there any post, where one could vote on it? Is there a CAR on it, please?
Cheers,
(2,857 Views)
Hi ghighuphu,
R&D is aware of this behavior, the CAR numbers are as follows:
CAR 152789 - Coercion dot appears when wiring Integer Array to Number To  Hexadecimal String.vi
CAR 152788 - Coercion Dot appears when wiring Integer Array to Number To Decimal String.vi
CAR 152787 - Coercion Dot appears when wiring Integer Array to Number To Octal String.vi
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments | Certified LabVIEW Architect
(2,823 Views)
